gtsum
Apr 20, 2015Explorer
Interesting..the PDI tech told me I couldnt tilt it (which shocked me). I will investigate further and see what I have from factory. OK, looks like I have a carefree awning, but it says shorter ones cannot be tilted (I have 2 main awnings because of kitchen slideout). I will have to play around with it at camping this coming weekend.
I did disconnect battery, so I should be alright there (as far as battery drain goes). Sounds like I am ok having the rig not leveled when the fridge is not running so I should be good there. I might look into the solar thing....question, anyone use solar panels to keep their fridge running while in storage?
Thank you all for the info..it really helps a newb like me!
Pic is below...I might talk to owner and see if he will run electric for me as he did for the rig behind me..then I could just plug it up and level it and be done...
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
