pjberny5's avatar
pjberny5
New Tires
Know this might start a major debate but I am looking at replacing the OEM tires on my Bighorn 3260EL. It currently has TOW Max STR 235/80R-16 E rated tires and after just a year and only about 7000 miles noticed some bubbles forming on the inside side wall on two of the tires. I'm very anal about inspecting and checking the air pressure and torque each time before we move. Not sure if this is just bad luck on these particular tires and replacing with the same brand and size or with their ST235/85R-16 would be the best or not. Have researched on the WEB but seem to find good and bad on almost all brands of ST tires.
Would appreciate any recommendations from your experience.
  • larry barnhart wrote:
    I would buy duravis 250 from bridge stone if you want another E tire.
    chevman
    These, or Michelin Ribs, if you want to spend more. :-) Upgrade to G-rated, if your rims will handle 110 psi.
    Lyle
  • pjberny5 wrote:
    Know this might start a major debate..
    It usually does, especially when Towmax and ST are mentioned in the same sentence. A search for 'tires' in the heading of this forum might serve you well.
    Funny.. just occurred to me that nobody says 'new to me tires'.
