Keep in mind here that FastEagle is an "internet Shill". His agenda is to keep you in the ST tires. He has changed his tactics yet again and is now attempting to sway the uninformed RVers by pushing the most expensive tire first.
The realities are that with 6000# axles, you are a perfect fit for the LT 235-85-16 tires. They are a little taller than the ST's you are dumping. If spacing between tires is to tight then the LT 245-75-16 tire will fit the same as your current tires. Both offer a load capacity of 3042# which will cover the rating of your axles. In all likelihood, your rims are also rated for 3042# at 80psi. If you want to go with the "G" rated tire that the "Shill" mentioned, then you need to verify that you have wheels rated for 110psi. If not, you would need to also buy new rims.
There are several manufacturers out there that make suitable LT tires that will serve you well. Check out the Michelin XPS RIB and the Bridgestone Duravis R250 for example. Both are steel carcas tires that have an exemplary record.
Keith
