I did not expect such debate. Wow!
So let me get this straight.
1. I have 6k lb axles/12, 000 lbs total
2. My OE tires were rated at 3, 520 lbs each/14, 080 lbs
3. LT tires are rated at 3, 050 lbs if I can remmber right / 12, 200 lbs
4. Pin weight I am not exactly sure, but im guessing around 2, 200 lbs. I did not see that stat on the sticker with the other info.
From the numbers alone:
1. I feel a possible concern with the weight rating of the LT tires. I will be at the extreme upper limit with load capacity of these tires. As compared to the OE ST tires. Another question, are the LT tires overloaded when seperated from my truck, no weight on the pin?
2. Has anyone ever had a bad experience with an LT tire on a trailer?
