Unless lube plates are coming in different sizes since I last put 1 on--just put it on. My Arctic Fox came with a 30 amp 25 ft cord. If need be--I have a 50 amp adapter which plugs in to the 30 amp cord and 50 amp outlet. Check tire pressure--good idea to have metal valve stems instead of rubber-make sure everything works including gas stove and oven-fill your propane tanks if Dlr. didn't. Get a lock for the hitch pin arm--and make sure you use it-never happened to me but have heard stories of arm being pulled out while camper is in public lots or campgrounds. Not much fun taking off only to find your camper pin box in bed of your truck. I use a combination lock. Lars
