ChadHubbard's avatar
ChadHubbard
New to me fifth wheel and hitch solution
Hi All
New to the Fifth Wheel Forum. Previously owned truck campers.
My wife and I were gifted a 2003 Fleetwood Pride 31-5G fifth wheel from her mother. It has been stored inside and unused since 2007. I have a 2014 Ram 3500, SRW, 4x4, diesel pickup, B & W turn over ball.
I backed the pickup up to the camper and the top of the bed rails was even with the bottom of the camper - 60" tall!! I had already removed the spacers from the truck rear suspension.
I was not willing to raise the camper 6" for the requisite clearance. It was already 13' at the highest point. My solution was to have a flat bed installed on the truck and weld a gooseneck adapter to the pin box. Multiple measurements indicated a 7" gooseneck pipe length from the top of the ball. Installed the pin box / gooseneck hitch today and hooked up to the truck. Pulled the camper out of storage. Camper sits level. I am satisfied with the solution. I know many do not approve of use fifth wheel conversion to gooseneck. Not my first choice either, but for those with an older fifth wheel trailer and a newer pickup, this may be a solution for them as well.
I will try to add a few pics to show the pin box / gooseneck adapter and the trailer hooked to the truck.
Planning our first outing in 2 weeks.
[img]C:\MyFiles\Pics\FleetwoodPride\HitchWithGussets.jpg][img]C:\MyFiles\Pics\FleetwoodPride\GooseneckHitch.jpg]
[img]C:\MyFiles\Pics\FleetwoodPride\CamperFrontHitch.jpg][img]C:\MyFiles\Pics\FleetwoodPride\RtSideTruckCamper.jpg]
  • It looks like the GN is rigidly mounted to the trucks frame? If so I suspect that would be better for the fiver than the adapters are because they basically have another hinge point.
  • Nice setup, I am assuming the bed cost about what the RV is worth. Sometimes money is not the issue!
  • Nice solution to a common problem. My trailer is an 08 and will in no way fit a new truck. It certainly limits the pool of potential buyers. It's too bad you had to lose your truck bed however that aluminum flat bed looks nice. My guess is they didn't give it away.
    Welcome to the forum. I've been her a while and still can't post a picture.
