2012Coleman
Sep 01, 2021Explorer II
I can make a great suggestion on the fifth wheel for a couple - Grand Design 337RLS. Opposing slides in the rear make a very large living area. The bed/bath is very spacious as well with a walk in closet at the front and washer dryer hookups. You can tow it with a SRW 1 ton truck. You can get into the fridge when the slides are closed if that's important to you - can also access the front bedroom.
I'd also suggest the long bed and the B&W Companion. I have the short bed with the B&W manual slider. If possible, go with a diesel engine - better MPG and a WAY better towing experience - especially if full timing.
Arctic insulation is a myth. There is only so much insulation you can get into a thin RV wall. The electric fireplace helps a lot but if you try living in it in extreme cold, you will be miserable - but then you can always move. Good luck
About Fifth Wheel Group
