DutchmenSport
Mar 29, 2016Explorer
Well, it's quite obvious someone else already beat me to the "bad news." Here's the stats on the unit the OP is considering!
http://ddrv.com/rv/2016-winnebago-spyder-24fq-24fq-gg001/
WEIGHTS & MEASURES
Exterior Height: 11'11"
Exterior Width: 8'4"
Interior Height: 8'2"
GVWR (lbs.): 10,400
Dry Weight (lbs.): 6,940
Axles (lbs.): 2 @ 5,200
Tire Size: ST225/75R-15D
Fresh Water (Tank Only) (gal.): 100
Black Tank Capacity (gal.): 41
Gray Tank Capacity (gal.): 41
LP Capacity (lbs.): 40
LP Capacity with Upgrade (lbs.): 60
Furnace (BTU): 25,000
Water Heater (gal.): Continuous
CHASSIS
Powder-coated I beam
Dual axle
Split fuel tank (41 gal./18 gal.)
3 toy lock loops welded to frame
4-corner stabilizer jacks
2,000-lb front tongue jack
Correct track alignment
Equa-Flex Suspension System - See more at: http://ddrv.com/rv/2016-winnebago-spyder-24fq-24fq-gg001/#sthash.rnVGpfHX.dpuf
WEIGHTS & MEASURES
GVWR (lbs.): 10,400
CHASSIS
Dual axle
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
