atwowheelguy
Apr 04, 2016Explorer
wpsharpshooter wrote:
Well it looks like we found a hauler that will fit what we needed.. Found a XLR Hyperlite 24hfs. Plenty of room in the garage portion and comes in at 5600 lbs dry..
I hope it works out for you. Did you check your payload? My camper started out in the brochure with a dry weight 1,000 lbs. lighter than that one and ended up loading the truck rear axle to within 50 lbs. of its weight rating. I think you'll need to be aware of putting all your cargo in the camper instead of in the truck. Good luck with it.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
