wpsharpshooter
Apr 05, 2016Explorer
atwowheelguy wrote:wpsharpshooter wrote:
Well it looks like we found a hauler that will fit what we needed.. Found a XLR Hyperlite 24hfs. Plenty of room in the garage portion and comes in at 5600 lbs dry..
I hope it works out for you. Did you check your payload? My camper started out in the brochure with a dry weight 1,000 lbs. lighter than that one and ended up loading the truck rear axle to within 50 lbs. of its weight rating. I think you'll need to be aware of putting all your cargo in the camper instead of in the truck. Good luck with it.
Here is the info
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
