tsetsaf's avatar
tsetsaf
Explorer III
Feb 21, 2014
New Trailer, Crummy Tires Need Advice
We have purchased a new 2014 model year trailer from a private party (they bought it new in Oct). It is a triple axle with 225 75 15 Tow Masters not sure if they are D or E but it doesn't matter because they are not staying on the unit. The axles are 33" spaced so they have room for a 16" with 225 75 16.
I have also considered the Maxxis LRE in the stock size but after the bad luck I have had with ST tires I really want to put some Duravis R250s on this thing and never worry about it.
Is my only concern the clearance to the underside of the trailer?
Will the larger tires impact turning, deflection of tires, or anything I have not even considered with the triple axle?
  • ol Bombero-JC wrote:
    Lots of 5th wheel triple-axle Toy Haulers.
    They might be a great source for info.
    (IMO) very few of the TH folks will see your post on this forum.
    You might ask on the Toy Hauler forum - after modifying the
    title - as no duplicate threads are allowed..;)
    MODERATOR could you move this to the toy hauler forum?
  • The LT E at 80 psi has much less carcass flex trhan the softer sidewall 65 psi D tire.
    I see the 15" ST225/75 -15 has a 8.8" over all width vs 9" over all width for the LT225/75-16" which = around .10 wider on each side. I doubt you will have any issue with tire rub especially with the stiffer LT E carcass.
    The LT225/75-16 E shows a 29.4" dia vs the ST225/75-15 D or E at 28.3" dia.
    I have 5200 lb tandem axles with std leaf spring suspension on my 5er and 16" LT215/85 E tires. I have 2 3/4" clearance at the top. No rub issues.
    My tire dealer will mount different sizes of tires on my trailers if need to get proper clearance. Your area tire dealer may also help you in that area as you are buying 6 tires from him. I still use the OEM 15" ST as a spare and has never on the ground.
  • I too would be concerned if I had Tow Master ST tires on a heavy unit.
    You can go to the tire manf. websites and find the tire width, and hight to see if you have enough clearance for a different size tire.
    And you will have to buy 6 new rims if you change from 15 to 16 inch tires.
    I replaced Tow Masters with Maxxis, 4 years ago, and I am totally happy with them. I don't know how many miles I have put on them, but it includes three coast to coast trips. They are pretty good tires within their weight range.
  • Lots of 5th wheel triple-axle Toy Haulers.
