2001400ex
Jul 09, 2018Explorer
Problem is, some things don't pop up until you use them. I did a thorough PDI but I didn't know my faucet would turn on in transit. Or that my carpet would crumble. Or that the low voltage indicator would beep in the middle of the night when the furnace kicked on. Or that a screw would be loose causing the solar panel to go into over voltage mode.
Then the dealer will lie...."yes the new ones, the bed will be super loud when moving up and down" or "yes the tires should be at 65 PSI when the tire says cold at 80 PSI. I've worked at a tire shop for 10 years". Yes both of those are direct quotes.
Luckily I have a great dealer by me that loves warranty work. Best advice is to use the camper and be diligent in getting warranty work fixed.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
