laknox
Jun 12, 2019Nomad
Planning wrote:laknox wrote:Brad NSW wrote:
Thanks PLANNING. Parts on order. Looks like an easy fix and bad check valve makes sense.
If you've got a NEW pump that's backflowing, why wouldn't you warrant it for another one, that works correctly, instead of bandaiding the defective one? :h
Lyle
Because the Shurflo check valve is an historical single-point-of-failure, and a dedicated check valve is a more positive remedy not requiring repetitive repair.
No matter. A new, and properly functioning pump is what was paid for and what should be delivered. If it fails later, then install the other valve.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
