joelmyer
Feb 23, 2014Explorer
djgarcia wrote:
Crazy Sadie,
Hooking up a 5th. wheel is not difficult and easy to learn. Suggest you have a friend who has a 5th. wheel, help you the first time you hook up. Just a couple of basic steps that will be helpful and keep you out of troublel:
1. when backing up to the trailer, make your trailer hitch comes in low enough to make the plate level, better a little low than too high.
2. Bump test. After you hook up the truck and trailer, raise the front jacks so they are about 1 inch off the ground, put a 4X4 block of wood in front of the 5th. wheel tire, slowly pull forward as if you were getting ready to take off. If the 5th. wheel stays hooked up then you know you hooked it up ok. If it comes apart then the 5th wheel will only fall 1 inch with no damage to your truck or trailer.
Easy.
I call #2 the pull test & do it immediately after hooking up with the jacks still down. You can feel the resistance.
Then, before putting the tailgate up, look at the pin. If you see the pin instead of the thing that grabs the pin, it's not hooked up.
Joel
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
