MFL
Feb 18, 2015Nomad II
You are correct. Pin wt. will most definitely get heavier, if you pack lots in front of the axles.
On average, most consider 20% of actual loaded FW weight, to be the average pin wt.
If you buy a trailer, that is right on the edge of your trucks capability, for pin wt., when empty, you will have to watch where you load every item.
The payload of truck needs to be considered too. If full of people and gear, plus a maximum pin wt. of 2,584, you will likely go too far over your GVWR.
If you keep the pin wt. closer to 2,000, it will give a little more passenger payload.
Jerry
Jerry
About Fifth Wheel Group
