shum02
Dec 15, 2015Explorer
MPDano wrote:
Per manual:
4.6 L
3.55 Rear Axle Ratio
(17 in) Wheels
(11000 lb) GCWR
(0-5500 lb) Max Trailer Weight
There is nothing mentioning about Tongue Weight.
I was looking at one the megalite TH's. Specs like this on a 23'
Model: Extreme Mege-Lite 23LT
Length 27'6"
Width 8'0"
Height 10'5"
Dry Weight: 4780 lb.
Axle: 2
Tongue Weight: 630 lbs.
GVWR: 7640 lbs.
Fresh Water: 100 gal.
Gray Water: 35 gal.
Black Water: 35 gals
The dry weight is fine but the GVWR will kill that little 4.6L. I have one in my '98 F150 with 3:55's and towed a 5500lb HTT. Had to shut the a/c off on some hills in NY State just to stay close to the speed limit with the engine screaming.
You're not going to enjoy driving that combo.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
