Blackdiamond
Dec 15, 2015Explorer
The 4st is about 275lbs+ with gas and the protection you added , the 2st 250lbs, the quad 300, buggy (can't really tell what it is) 1000 lbs, gas 20 gal for the weekend 126 lbs, riding gear, tools, spare parts, propane, food, beer, cooler figure on the light side 400 lbs...right there you are at 2350 lbs.....it adds up quick then you start thinking about fire wood and all the other stuff(yes there is other stuff).
Your 23ft trailer (that is really about 6500 lbs empty and already over your tow rating) is going to be way more than you should safely pull.
I just don't want you to be the guy that invests in the TH and after 2 trips decides they need a bigger TV and then decides, well now that I have the bigger TV I can get a bigger TH, seen it happen too many times.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
