MPDano
Dec 16, 2015Explorer
horton333 wrote:
I towed a 30' toyhauler with a 4.6 Explorer for 10 years, worked great. I believe you have a solid rear axle and the vehicle weight is higher so you will have a slightly worse overall experience from both handling and power on the hills, but the trailer being much shorter I would not see any problem as long as it is setup properly.
That is an old vehicle, have you changed fluids in the transmission and differential?
The only time I felt any issues was when moving my son (all too frequent an occurrence while he goes through school with his half ton, literally, of books) when the weight would go north of 8,000 and the hills were a bit of a challenge (I had undersized tires, so I had effectively a 4.73 rear end). I doubt you will ever be anywhere near that weight.
Thanks for this. I try and stay up on my fluid maintenance. I have never changed out the Diff fluid tho. I guess I should start.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
