Golden_HVAC
Aug 28, 2015Explorer
Two honda 2000 generators will run the 15,000 Btu A/C. Their combined surge rating is 4,000 watts, plenty to run the A/C and also run a microwave, TV, couple of computers ect.
Yet if the A/C cycles off, and you are making coffee, or running the microwave, that 1,500 watt load along with the starting surge of the compressor might be a bit much, it 'should' work, but you might also need to shut off the microwave if the generators start to lug and don't sound right while starting the compressor.
Check out this place for pricing. Mayberrys.com They can not post any pricing over the internet except retail, and they sell well below retail. You have to call for the correct price, shipping included.
They know RV's and will sell the right adapter between the two generators, with a 30 amp RV style plug on it. Many Honda dealerships might stock a plug that is twist lock, the type used in construction sites or something. . .
GOod luck,
Fred.
Many are impressed with the pair of easy to carry 47 pound generators, they will work just as well as a Costco $500 5,500 watt generator, but those are 150 pound monsters, and very loud! Get a quiet Honda, your neighbors will thank you.
Also if you like to camp in places with 30 amp only sites, and they tend to have low input voltage, you probably want to buy a Kill-A-Watt meter to monitor the voltage, and shut off the A/C when it is less than 105 volts. And probably want to consider a voltage booster, like Autoformer if you have problems with low voltage. IT will automatically boost the voltage by 3% every time you plug it in, and will switch to 12% boost mode when you need it due to poor wiring in the (most often) 30 amp RV park sites.
GOod luck,
Fred.
About Fifth Wheel Group
