HendricksK9 wrote:
I heard a few years ago that people with mega cabs had turning problems and would forget and put the cab of the truck into the front of the hauler. I'm wondering if there is still that problem with the 2012's or did Dodge fix that issue.
This was never a "Dodge" issue. It's because you have a Megacab which means a short box. It doesn't matter which brand of truck, anyone pulling a FW and not just a TH FW can run into that issue. Just keep yourself aware of when your turning. I think most people with FW and shortbox pickups run into the issue when trying to backup. I know that Heartland FWs in general and the Cyclone too have the special front cap that can allow you to turn 88 degrees or something in a shortbox without hitting the front of the FW. You might look into that as an option. Otherwise do a search on here for short box pickups and FWs. That topic has been discussed many times over.
As for Keystone vs Heartland? I'd take the Cyclone. Only one I've really heard horror stories about is the Dutchman brand I believe on their Voltage is it?
