Butch50
May 29, 2018Explorer
laknox wrote:RonnieBoggs wrote:
So I purchased the B&W Slider hitch and had it installed in my Ram 2500 diesel. Now I want to use my bed for hauling drywall, but I cannot figure out how to remove the base. The instructions say to loosen (not remove) the bolt in the center of the base and pull the handle located under the driver side while to release the base. This combination is NOT loosening the hitch base. I must be doing something wrong or missing a step. Could somone step me through the removal steps and assume I'm brand new...because I am!
Ronnie
Lake St. Louis, MO
Keystone Impact 361
2013 Ram 2500 Diesel 6.7
You may have to tap the draw-down bolt to get it to loosen up so the cross-pin can be pulled out.
Lyle
I agree, I had that happen to me many times. A little tap to force the bolt down that loosens it below and allows the rod to slide out. Then like also stated it may have to be pried up a little.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
