dtzackus wrote:
I have seen 5th wheelers parked at our campground (as we are perm. for now) and I see every now and then, a tripod is connected to the hitch part of the nose part of the 5th wheel. Dose it help with stability?
No, waste of money. JT Strongarms or Steadyfast.com units work.
dtzackus wrote:
Unfortunately, we only have 30 Amp service, but I already have a 50 Amp to 30 Amp cord, so I am good there, will I be able to run both A/C units or should I turn one off?
You need 50 amps to run both AC units. 30 amps will run one.
dtzackus wrote:
Last question, I am sure I will open a can of worms with this one, what hitch for the truck does everyone recommend? I currently have a 6 1/2 box.
Andersen Ultimate 5th Wheel Connection - aluminum version is 35 pounds. Save payload. Save your back. Store anywhere.
