Old-Biscuit
Nov 30, 2015Explorer III
TrickyRicky wrote:
Old Biscuit I have to disagree with your purging instructions. My method would be to fill the tank with vapor propane at a pressure of approx 15 psi and then bleed it off and redo it 5 more times this will flush almost all the air and associated contaminates from the tank now it can be filled.
I gave the shorten version of 'purging' cause that is not OPs issue. Her cylinders are not brand new just empty.
And I could have copy/pasted those instructions from website also.
MY question about purging and how it controls the amount of propane placed in the tank. These are two operations and yes a new tank is to be purged. If the tank is filled without purging in the normal manner of opening the spitter valve and with the tank on a weigh scale then the same amount of propane should be in the tank when liquid propane starts to exit the spitter valve and the scales show the proper weight . Without purging some moisture and contaminates may still be in the tank.
Sometimes the high flow valve on new tanks may be stuck from somebody opening the main valve with a high pressure of air escaping similar to a propane leak. If this condition exist then it will not be possible to purge or fill the tank.
Unless a hose is connected to cylinder OPD opening it will not allow anything to flow due to spring loaded shutoff that has to be held open by stub inside hose ACME nut.
And the high flow (Excess flow device) is internal part of ACME nut.
OPD has shut off float, bleeder port, relief port and spring loaded shutoff
OP has a leak
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
