- mpfiremanExplorer
camp-n-family wrote:
So bearings may sieze causing wheel to separate but you're supposed to bring it to the dealer to be inspected?? Sounds like a good idea.
This is a typical catch 22 situation. Same thing happens with faulty tires. - camp-n-familyExplorerSo bearings may sieze causing wheel to separate but you're supposed to bring it to the dealer to be inspected?? Sounds like a good idea.
- MFLNomad III have seen this many times on various types of new trailers. It seems the factory only wants to use 25 cents worth of grease, instead of the whopping $2.00 worth required.
I've always checked the bearings for proper grease, on new or used trailers.
Maybe a recall on Keystone will help to awaken all the RV manufacturers.
Jerry - mpfiremanExplorer
downtheroad wrote:
oops...looks like someone forgot to lube the wheel bearings.
That happened to us on our first TT. As we were going on an extended trip, i checked every wheel, and found two without the proper amount of axle grease. They were almost dry. - downtheroadExploreroops...looks like someone forgot to lube the wheel bearings.
About Fifth Wheel Group
