laknox
Sep 27, 2017Nomad
aruba5er wrote:
They keep raising the trucks and I am running about 2 inches nose high. I blew 3 tires in March and still trying to figure out why. How much more weight is on the rear tires because of "nose high" I had to adjust the hitch 3" up when I went from 2007 2500 HD to 2011 Hd and the new 2017is almost 3" higher again. Because of that I have decided I don"t need a new truck. I thought that the equalizers would change the weight to "equal" but does it? Any thoughts?
For what it's worth, they could drop the truck 11" and still have room for tires. And it would be a whole lot easier for us old farts to get into.
Personally, I'm 3-4" nose high and I've not noticed any temp differential between front and rear tire when towing, either empty or loaded. I =do= notice sunny/shade differences of 10-20 degrees, though. This being said, I simply don't think there's enough weight transfer between front and back axles to worry about, especially since I'm upgraded from D to E-range tires. This is =my= experience, with =my= rig; YMMV... I do know that some trucks have spacer blocks in their suspension that can be removed to lower the truck some.
FWIW, I do agree that today's trucks are just too d@mn high, and it's done for marketing and nothing else.
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
