aruba5er's avatar
aruba5er
Nise high towing How much additional wieght on rear tires
They keep raising the trucks and I am running about 2 inches nose high. I blew 3 tires in March and still trying to figure out why. How much more weight is on the rear tires because of "nose high" I had to adjust the hitch 3" up when I went from 2007 2500 HD to 2011 Hd and the new 2017is almost 3" higher again. Because of that I have decided I don"t need a new truck. I thought that the equalizers would change the weight to "equal" but does it? Any thoughts?
For what it's worth, they could drop the truck 11" and still have room for tires. And it would be a whole lot easier for us old farts to get into.
    This is a very major reason I drive a 2wd '04 truck. It is only 52 " at the tail gate empty and settles 1 1/2 inches with the 5th hooked up.
  • Just my opinion, but the equalizer should balance the weight between axles. But, with the trailer nose high, the rear axle has limited remaining suspension travel and so the rear tires experience more abuse. That is the downside.
  • YOu need to weigh it.
    Many times the DOT scales on the freeways leave their scales on so even if they're closed, you can stop and weigh your rig.
