Was using the furnace tonite but noticed the fan kept running but the air from the vents were cool. Swapped tanks but didnt make a difference. Got propane at the cook stove. What should i look for?...
Well, heat worked this morning when i tried it. This is not the 1st time this happened.
Thermostat set at 80, just blows cold, temp unside was 61. Wondering if burner uses 12v to ignite, and does that 12v come from a converter or directly off the batteries?
