Was using the furnace tonite but noticed the fan kept running but the air from the vents were cool. Swapped tanks but didnt make a difference. Got propane at the cook stove. What should i look for?...
NWBound, look for NOCO oil-based battery terminal anti-corrosion spray. Can be found at WallyWorld. Been in business since 1914, so they must be doing =something= right. I recently got a small spray can that also came with the treated felt rings, so belt 'n suspenders for me. Any time I've used these products, I've had almost no corrosion; when I =don't= use them, I tend to have issues. No brainer, here...
