Was using the furnace tonite but noticed the fan kept running but the air from the vents were cool. Swapped tanks but didnt make a difference. Got propane at the cook stove. What should i look for?...
If you check the battery terminals, you will see the wires that come from the converter. Using a multimeter, there should be at least 12.3 volts coming to the battery. If not, the converter is the problem. Just remember, when you replace it, you can go up in amperage for a replacement, but you can't go down. For instance if it is a 75A, you can go to an 80A, but not a 60A. I just replaced mine in my 3 year old Sandpiper right before our Montana came in.
