Was using the furnace tonite but noticed the fan kept running but the air from the vents were cool. Swapped tanks but didnt make a difference. Got propane at the cook stove. What should i look for?...
I would tend to think you are correct. Mine was very easy as it stopped putting out at all. But have heard of them doing this very thing. One other thing I would check with a multimeter, is the current at the wires coming into the unit with the unit plugged to make sure your plug is good and a wire hasn't come loose in the plug.
