- Roger10378Explorer II
allen8106 wrote:
Roger10378 wrote:
If it was working and then quit without you doing anything it is probably the check valve on the output of the water heater.
Obviously I've not seen all RV hot water heaters but I've never seen a check valve on an RV hot water heater.
Only the water heaters with 3 valve winterizing systems don't have a check valve. - howardwheelerExplorerI had this exact problem and it was the check valve. I completely removed mine as I don’t need to winterize.
- allen8106Explorer
Obviously I've not seen all RV hot water heaters but I've never seen a check valve on an RV hot water heater. - laknoxNomad
dustinl wrote:
fixed, thanks ill post another question about a clogged toliet soon
So, it =was= the check valve?
Lyle - dustinlExplorerfixed, thanks ill post another question about a clogged toliet soon
- Roger10378Explorer IIRemove the pex from the check valve and you will probably be able to remove the loose bits of the check valve. Reinstall the fitting and you will be good to go. Just replace the check valve before it is time to winterize if you use the pink antifreeze. I do not use antifreeze when I winterize mine so I didn't replace the check valve.
- Me_AgainExplorer III
dustinl wrote:
how do I check this?
Replace it. Get the brass one to replace what is most likely a plastic one. Chris - dustinlExplorer
how do I check this? - rv2goExplorer II
Roger10378 wrote:
. X2
If it was working and then quit without you doing anything it is probably the check valve on the output of the water heater. - Roger10378Explorer IIIf it was working and then quit without you doing anything it is probably the check valve on the output of the water heater.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
