agesilaus wrote:
With fifth wheels the critical truck stat is carry capacity not tow weight. Use 25% of the max weight of the fver as a rough estimate of the pin weight of the fver. For example on a 10,000# max weight fver, use 2500# as the pin weight estimate.
Then then subtract from the trucks carry weight: pin weight + 200# hitch weight + weight of the passengers + any thing else carried in the truck. If you come up with a negative number then you have a problem. This is a big problem with most 3/4 ton trucks.
Totally agree with this statement! Do the math FIRST then the purchase. You'll thank yourself later.
Dan
