Bobandshawn wrote:
agesilaus wrote:
With fifth wheels the critical truck stat is carry capacity not tow weight. Use 25% of the max weight of the fver as a rough estimate of the pin weight of the fver. For example on a 10,000# max weight fver, use 2500# as the pin weight estimate.
Then then subtract from the trucks carry weight: pin weight + 200# hitch weight + weight of the passengers + any thing else carried in the truck. If you come up with a negative number then you have a problem. This is a big problem with most 3/4 ton trucks.
Agree with this as well. I have a 4X4 2500 Mega Cab with the 6.4 gas Hemi and 4.10 gears. The payload on this is 2,903 lbs and towing capacity is 15,250. This is a higher load rating than the heavier Cummins diesel version of the same truck. The diesel model has a payload rating of 1,995 lbs, almost a grand less, and the tow rating is 50 lbs less at 15,200. The Ram 3/4 tons with a diesel are only available with a 3.42 axle gear now. The diesel has less payload due to the added weight of the engine. So even if they had a 3.73 or 4.10 gear ratio on those the payload would remain the same.
So from your calculations I need to stay with a pin weight of about 1500 lbs or so. Now much trailer!!I got such a deal on this truck I may trade up for a CTD Mega Cab dually. LOL
Yeah you might. lol It's too bad you got such a good "deal" on your truck, now you're pretty limited to what you'll be able to pull. Kinda of hard to look into the future when buying a truck sometimes.
We started out with (buying) a one ton dually then looking at trailers so we could avoid the very situation you're facing now. You can't have too much truck IMHO. :B
Dan
