Mile High wrote:
SanMarMor wrote:
I think 25% calculation for pin weight is on the high end, unless you're in a bigger trailer. Ours is 36' with a gross weight of 13xxx pounds. When I weighed it lightly loaded, it weighed 111xx pound, and the pin weighed 20% actual weight.
Mark
I think I would agree - Ours is 25% but only when fully loaded with gear and 110 gals of water that sits under the front basement. We are 17,222 total 5er weight and with water and pin is 4,320 lbs. comes out about perfect to 25% but this model is way nose heavy by floorplan. Other floorplans aren't nearly that nose heavy in ours.
"Most" 5th wheels will have at or near 25% pin when full timing since MOST of the weight added will be added in front of the RV axles. If you are pushing the limits of your TV best to figure 25%.
