norfla71
Dec 01, 2013Explorer
Non-heated holding and water tank options
Ugly surprise this past weekend; had guest stay for a week in the hauler, none of our tanks are heated/enclosed and the temps dropped into the 20's. Holding tanks were nearly empty, and had anti-freeze dumped in. Water tank, however, was full (drain is not working for some reason) and nearly burned the pump due to freezing.
We are exploring other trailer options for the future, but will need to keep this for at least another 7 - 10 years. From research I discovered the easiest way to protect and heat the underbelly is install skirting and use a space heater; however, the skirts are custom and run over $1,000 a set. Anyone have a cheaper alternative, or is a custom set the best bet? I've also thought about tank heat pads, but not sure.
