- lj2654Explorerthese high temp boxes are terrible, Think they are on revision"f" maybe now. I have an "E" and my red light came on with the frig turned off, overheat when off, yea right.....
- BrinksongsExplorerThanks...will do :). Brink
- Old-BiscuitExplorer III
Brinksongs wrote:
2015 Montana 3402. Red light is on when refrigerator power is on. Bought new and have only had 5 days. Dealer closed today.
Contact them tomorrow AM......
Keystone warranty....PLUS Norcold warranty
Probably bad electronic in box.
Only Norcold authorized service can verify/replace - BrinksongsExplorer2015 Montana 3402. Red light is on when refrigerator power is on. Bought new and have only had 5 days. Dealer closed today.
- Old-BiscuitExplorer IIINEW or USED RV??? What YEAR????
High Temp Limit Switch......OPEN
Means that temp switch has detected a very high temperature at perk tube/stack. That means that fridge cooling unit has failed (blockage/crack tubing)
OR
High temp controller has failed
But which one........real hogh temp or faulty device??
Do you have a 'Box with RED LED light ON' in outside compartment?
Can reset using a strong magnet.......place magnet against face of box and move back/forth until you hear 'click' and RED goes OFF
This will restore 12V DC to fridge and allow operation
BUT:
CAUTION: YOU NEED TO VISUALLY INSPECT COOLING UNIT TUBING/BURNER STACK/BURNER AREA FOR ANY YELLOW RESIDUE, ANY AMMONIA SMELL-------THAT MEANS CRACKED/BAD COOLING UNIT
DO NOT USE FRIDGE>>>>>>>>>>>>>>>>>>FIRE HAZARD
OR have an RV TECH Inspect and then if just faulty device vs bad cooling unit they can contact NORCOLD for replacement
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
