bodacious's avatar
bodacious
Norcold fridge "cycling"
Have a 2006 Norcold double door fridge with ice maker in new to us Escalade that I can hear constant "cycling" every 30 seconds or so. Everything seems to be cooling well. Is this normal?
  • Is the cycling you hear coming from the ice maker or from the refer burner?
    Icemaker could indicate that it has frozen up and cannot kick the cubes out.
  • Sounds like you may have a problem.
    Cycling should be in the 15 to 30 minute range at minimum.
