barney bugle wrote:
Thanks for the responses guys
It is a norcold model n814r serial 1101287 it is a 2003 model and I have operated it leval for the 4yrs I have owned it. It apparently has no fans and is an absorbent type ?
A norcold guy told me to bypass the thermozistor and see if that works . I am trying that now , but it does't appear to be dropping below 52 for one hr now.
What thermistor are you going to bypass? Just might be the fan control. I just helped a friend sort his problems out and due to the intermittent nature it took a bit of effort and patience.
Did you put some water in the vent tube drain to cover the end of the tube? This is just a simple test.
