sk734's avatar
sk734
NORCOLD fridge
Running to cold. Change out thermistor which is the only temp control. Model N811vf for. Has defrost cycle. Any ideas? Thanks
  • No error code. Moved thermistor same problem. It has a defrost cycle that seems to be a problem. Thanks for help and ideas.
  • Is Indicator Light 'Flashing' off every 20 seconds ????
    Green Flashing Light...operating on AC but in 'BOS' Mode
    Amber Flashing Light...operating on GAS but in BOS' Mode
    BOS.Backup Operating System...faulty thermistor
    That is a first a nevercold to cold. Move the sensor that is chipped on a cooling fin inside the box to a different position. I forget whether closer to the sidewall is cooler or warmer. I think it is warmer? Chris
