This was my first outing with new FW and needed to check how level when hooked up. My rig is 41 ft long and I am three inches high in front. Should I be concerned? Hitch is properly set for tv clear...
First thing I would do is weigh your RV's rear axle and make sure you are well within the tires ratings. Second thing I would do is look at the TV tires are they load range "E" or did someone stick "D" on there and justify that the load rating is as much as the stock tires.
