RocksrideExplorerDec 01, 2015Nose highThis was my first outing with new FW and needed to check how level when hooked up. My rig is 41 ft long and I am three inches high in front. Should I be concerned? Hitch is properly set for tv clear...Show More
tsetsafExplorer IIIDec 01, 2015Only way to know is to scale each axle loaded up. Are you overloading the rear most axle/ tires? If not then good to go.
