IdaDExplorerJan 23, 2016Nose highWhat sort of options do I have to help level an older fifth wheel with a newer truck? Pic below - is that too far off level? The pin is sitting on an Anderson at its lowest setting. I've only got ab...Show More
rhagfoExplorer IIIJan 23, 2016If your axles are currently above the springs you can gain about 4" by placing the axles under the springs. You will need new spring saddles.
