IdaDExplorerJan 23, 2016Nose highWhat sort of options do I have to help level an older fifth wheel with a newer truck? Pic below - is that too far off level? The pin is sitting on an Anderson at its lowest setting. I've only got ab...Show More
rhagfoExplorer IIIJan 23, 2016If you have some decent tools not real difficult, I did on a 24 year old King of the Road, with more than it's fair share of corrosion.The one on the left is done, the one on right is waiting. Make sure you have solid support under the 5er while working. 2X4 cribbing worked well.The After picture.
