What sort of options do I have to help level an older fifth wheel with a newer truck? Pic below - is that too far off level? The pin is sitting on an Anderson at its lowest setting. I've only got ab...
I did the axle flip myself, I removed the axles and took them to a welder and had the new perches welded on then reinstalled myself. While you have everything apart I would recommend adding a EZ Flex equalizer and wet bolt kit.
