IdaD
Jan 23, 2016Explorer
Nose high
What sort of options do I have to help level an older fifth wheel with a newer truck? Pic below - is that too far off level? The pin is sitting on an Anderson at its lowest setting. I've only got ab...
N-Trouble wrote:alexleblanc wrote:
Look at some 16" tire + wheel option, you can possibly gain an inch or more extra height.
You have to first make sure you have adequate clearance in the wheel wells above the tires to do this or will rub. Without an axle flip he likely doesn't have much room in there for a larger diameter tire. Also has to check axle spacing.
