jaycocamprs
May 28, 2018Explorer
BB_TX wrote:
If you plan to never use them and there is easy access to where they are tapped into the rest of the water system, I would either cap them off or put in a shutoff valve in each line to eliminate possible stagnant water in them. Mine are connected to the water lines under the bathroom vanity and would be relatively easy to do either. But we have a washer and use them.
This is exactly what I did after several times of winterizing the connections in the closet. Got caps and removed the lines from the tees under the sink and capped them off. Had to take out a panel under the sink, but easy job. Someday we may get a washer and if we do they will be easy to hook back up.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
