RobWNY's avatar
RobWNY
Not using the Washer and Dryer Hookups
During the PDI for my new 5th wheel, I explained to the dealer that I wouldn't be using the washer and dryer hookups that are located in the bedroom closet. He wasn't clear when asked about what to do when Winterizing and De-Winterizing those connections. He said just use a bucket or something when De-winterizing this Spring and after that, not to worry about the washer/dryer connections and lines again. I specifically asked about running Anti-freeze through the lines like you do for the rest of the camper when winterizing in the fall and he said it wasn't necessary. That just doesn't seem right to me. The Manufacturer put anti-freeze in those lines before shipping the camper to the dealer so shouldn't those connections be treated as any other faucet would be going forward? What would be the best method to use so there's not water/anti-Freeze all over my closet area? I was thinking about attaching a hose to both valves and have them drain into a sink. Is there another method used that might be a better solution or was my dealer correct when he said after De-Winterizing, not to worry about those connections again?
  • sch911 wrote:
    On our MH those lines drain nicely when the low point drain is open. Then I use the blow out method without antifreeze. I open all valves one by one including those two when the system is being blown out.
    BINGO!!!!!! We have a winner!!!!!
    Don't forget to blow out the "P" traps, don't ask. :(
  • I winterize the washer hot/cold water connections thru access panel in bedroom closet using short washer hose and bucket. I run RV antifreeze from outside hose inlet utilizing water pump. Been doing this for 10 plus years...works for us. PS, this is done after hot water tank is in bypass.
  • On our MH those lines drain nicely when the low point drain is open. Then I use the blow out method without antifreeze. I open all valves one by one including those two when the system is being blown out.
  • You need to clear the lines of water. A garden hose connected to each one would help.
  • They are water lines, they contain water, water can freeze. The dealer is clueless. If you are sure that the lines will not be used again, disconnect them so that they won't be holding stagnant water forevermore.
  • I guess I don’t really have an answer for you but my 5vr has washer/dryer hookups that we have also never used We have had this one since 2011 and live in ND and I have never done anything to winterize the lines other than normal winterization. All is fine with those lines after many cold winters. Hope this helped.
