Ben,
I own Artic Fox Silver Fox Edition fiver. We did tons of research
trying to locate the "perfect" fiver within our price range. It
does not exist. Compromises are based on priorities as with all
RV purchases. In the long run you will probably find that floorplan
trumps all....with functional storage being a close second.
The Artic Fox we purchased had the usual piddly issues on arrival,
most caught within the intial PDI. As the "warranty" is only 1 year,
I would suggest you time your purchase to the "best season" of use...
that way you uncover blems/malfunctions/issues not readily apparent
in the PDI. Some only "show" under real world use.
Overall, good quality "bones", good fit and finish, nice eye candy
appeal, comfortable. If we had a "do-over" the RV furniture is a
disappointment...have already pulled the hide-a-bed sofa and replaced
with a modern era futon (too much work, and not comfortable). The
swivel rocker recliners will be next...require downward dog yoga position
to close...on the third attempt.
Some "what were they thinking" moments... fuse box on the floor, with a
lid that opens up.... hope you keep your kitchen floor clean as your
face will need to spend some quality cheek time on the linoleum. The placement
of GFI plugs is great as are the plugs in general. Well thought out lighting
with leds'/spots/flour/bulb combo. Excellent cabinet work..but a 2 rung
step-stool necessary to reach higher altitudes. One touch
black/grey dump is a fan favorite as is the power creel on the 50 amp cord.
Slam latch doors are reassuring as are plenty of external/storage lighting.
Another point of positivity... based on where you live... proximity to
the Northwood factory would factor in to my decision.
Cannot address your tow vehicle... mine has no problem towing or
stopping our fiver. We are fans of winter desert camping / Ca. beach so
mountain peaks do not really play in to our RV plans at present.
Your usage may vary.
There are lots of good builders out there.... I think we chose well ...time will tell...
my goal, ten years of moderate use with just routine maintenance schedules and
I will be happy. Good luck in your choice.... funny , all the hours and hours of research...
and we really knew as soon as we stepped in to the unit.
Hope I don't seem like a "homer" (ie mine is best), take your time, step in to
lots of RV's , check out the user forums, and make sure your bride is happy
with the choice. Also consider 5 year gently used.
Charles
