kopy kat wrote:
I've been thinking about adding a second spare tire set up to my rig--I saw one trailer that two mounted on the rear, and also one that three spares mounted on the rear.
Even though I run Maxxis tires, I know that one day one of them (or maybe more) will blow...
the question is...how many of you folks carry more than one mounted spare tire for your rig??
and is there a best place to order an additional 15" aluminum wheel for my Flagstaff 5th wheel?
thanks,
Larry
Wow - two & three spares mounted on the rear!
Confident campers?
(confident they will have flats).
"The question is..." - question:
Ans: One spare.
From the first TT I owned in 1975, I never carried more than one.
(They all had 15" rims/tires)
Traveled all over the USA, border to border - N-S-E-W.
When still working, had every 3rd week off, and with trades, frequent month long vacations were E-Z.
So, covered a lot of ground!
*Never* had a flat. Maybe just luck, but I always used LT tires.
(Broke a leaf in a spring once).
Same now with the 5th.
When I spotted a screw in one of the factory supplied GY Marathons, didn't pull it out - took it to a tire shop. (Still holding air).
Yep it made it thru the carcass - and with it dismounted, I found out why the ST Marathons are more appropriately called - "ST Balloons".
(And why FE admitted to at least 22 STs on his 5th)
Good bye ST Marathons - Hello LT XPS Ribs!..;)
Anyway - back to... where to carry your bandoleers of spares:
Rear bumper. (if you have one)
Under rear of 5th, cranks down pickup style (factory location).
Lippert makes a spare tire "slide-out" that mounts under the front of 5ers.
Seems PPL was advertising something similar to Lippert by another mfgr.
Or - you could just upgrade to 16" rims and *quality* LT tires..:C
