I have an Onan 5500 that has always started easily and run fine. Has about 240 hrs. I have a guy doing some inside work today so I showed him how to start it and turn the heat on as it was cold. He ...
I have a 5.5 onan 4 months old started good at dealer. got to the desert and ran for 3 hours then stopped. The gen is tested b4 release to the customer. BUT I was advised I had bad gas. replaced carb and drained out gas runs fine now, also if you have a fuel station have it drained to if you suspect bad gas. Use 91 octane use seafome run at least once a month for an hour at full load, two air conditions or etc
